M62 phone Samsung statick sound freeze lagg.... And so on
(Topic created: 05-23-2021 12:02 PM)
userCJEVeRGL9l
Other Mobile Devices
I bought phone last couple days and. I update it to april patch freeze lagg and statick sounds i reset it couple times same story anybody facing same problem ? Lagg freeze on this phone??  The problem when i hit priority mode the phone get super smooth then back slow even when i disable it it get smooth then 4 seconds trash performance. Weird phone and company new phone 2021 act like nokia 3310
SamsungRei
I apologize but you have reached technical support for products manufactured for usage in the United States. Please visit https://www.samsung.com/us/common/visitlocationsite.html to find your country's support page.
1 Reply
SamsungRei
