How does locating a Smart tag work?
(Topic created: 05-04-2021 01:38 PM)
userl9kONN3Nkn
Smart Home Support
Hi, I was just trying to work out.... With the smart tag I can only locate it when it is near my phone... I thought these were supposed to jump onto nearby devices to be able to be located?
Can someone help please?
Thank you
Stephanie Nikki
Black Hole
Smart Home Support
Here is a link to an Article with more information on the SmartTag: https://www.samsung.com/us/support/answer/ANS00088244/
1 Reply
Stephanie Nikki
Black Hole
Smart Home Support
