Volume Limit Pin
(Topic created: 12-11-2022 01:43 PM)
heisenbergg
Galaxy S22
I set a volume limit pin on limiting the volume of media's on headphones, and I don't know if i actually set one or not. So is there anyway to rest the pin or remove the limiter ?
KennewickMan
Black Hole
Galaxy S22
If that doesn't work then you'll have to go into settings>>general management>>reset>>reset phone settings.
You won't lose data; you'll just have to set up all your settings again, including customization.
KennewickMan
Black Hole
Galaxy S22
Settings>>sounds and vibrations >>volume>>3 dot menu in upper right corner>>media volume limit.
KennewickMan
Black Hole
Galaxy S22
heisenbergg
Galaxy S22
Wow it works, much appreciated. I also heard factory reset works, but who would want to do that, tysm!
KennewickMan
Black Hole
Galaxy S22
That's always the LAST resort, before sending in for servicing.
KennewickMan
Black Hole
Galaxy S22
Glad it worked!
