userXPZQhqJvpV
Media volume won't work a50
Hi,
Just want to get advice regarding on my a50 my media volume is not working i can't hear any sound when i play a video, spotify, netflix etc..  I already tried to do a factory reset but it is still not working. Any ideas on this. Ringtone and notifications works perfectly.
8 REPLIES 8
Re: Media volume won't work a50
When you press the volume key on your phone and then pull the volume down from the top is the media volume turned up?
userXPZQhqJvpV
I know the issue now. My phone is still recognizing the im on a headset. Ive already tried cleaning the port for headphone but still no luck. Any suggested steps?
Just to clarify, are you using a headset?
userXPZQhqJvpV
No im not using a headset.  It still recognising that im on a headset eventhough it is already unplugged. Screenshot_20191126-102622_Chrome.jpg
Have you attempted to wipe the cache partition for the device? Do you know if this still happens when your device is in safe mode?
userXPZQhqJvpV
Yup already tried wipe the cache also tried to do a factory reset. Yup it happens also in safe mode. Do i need to change ng headset port?
If it still happens in safe mode I would recommend having the device evaluated by a certified technician. You may have two options for this depending on your location, you can either visit a local uBreakiFix location or you can ship the device into the service center.
WiFi47
Someone who uses A50!
