- Mute
02-08-2022
11:37 AM
(Last edited
02-10-2022
10:56 AM
by
SamsungRei
) in
Hello.
I have a galaxy A12. In messages I have the bin messages that says any email over 30 days old will be deleted. I can not seem to find anywhere to change this. Can anyone tell me how or can I change it
Solved! Go to Solution.
- Mute
02-10-2022 10:54 AM in
Other Mobile DevicesHello, The trash folder of the Samsung Messages app does have a default of 30 days and then all messages in the Trash will be permanently deleted. Unfortunately, there is not a way to change this setting. If you do not wish for the messages to be permanently deleted, you would need to restore them.
- Mute
