MicroSD card transfer help?
(Topic created: 07-13-2022 03:54 AM)
userGGCC6ora9W
Cosmic Ray
Other Mobile Devices
I have a microSD in my phone and i'm trying to transfer the data in the internal storage in my phone on the microSD card my phone has 32GB and the microSD card has 128GB i formatted it but there's no difference on the internal storage and the microSD card i'm using a galaxy A10E
Transfer to the internal memory via Smart Switch. It will ask you what you want to transfer. Basically it's trial and error. There are apps that don't like being on SD cards. If you have a PC that might help you pick and choose what goes to the new phone more effectively. I had to experiment.
LongHiker
Epic Samsung Care Ambassador
@userGGCC6ora9W First use Device manager to see how much free storage you have remaining free. Your A10e only has 32 GB of storage to start with, so your free space is probably 10 GB or less.
If the size of data, on the microSD card, that you want to transfer is 80% or greater than the amount of free space on your phone... you probably will run into problems due to low memory.
