Phone charging says to check cable and will take over 3 hours?
(Topic created: 08-22-2022 09:06 AM)
XEEMON
Cosmic Ray
Other Mobile Devices
Hello folks.
I'm having an issue with my Samsung A52 5g phone, when I plug in the charging cable it shows a message that reads charging in three hours or more also it reads please check charging cable. When I unplug the cable and re plug again serveral time it works after 2 or 3 tries. I was wondering if this is common or if someone has an idea or a solution. Much appreciated and thank you in advance.
XEEMON
Cosmic Ray
Hey y'all. I did change charging cables and it worked. My phone is charging normally fine. Thank you all for your advice
AusetAuset
Mines was doing the same I had 2 buy a new charger
GaryB82
Samsung Care Ambassador
@XEEMON Sorry to say it sounds like your cable could be going bad i would suggest trying a new cable
If you've found my post to be helpful, Please like the post.
If my response resolved your issue, please press the Like and ✓ to Accept as Solution button.
GmaCelia
Switch cables
EVElectro
It could be a faulty charger
XEEMON
Cosmic Ray
