Phone thinks battery saving is on
(Topic created: 01-07-2023 04:24 AM)
Aldengraham
Cosmic Ray
Other Mobile Devices
Hi. For some reason my phone thinks battery saving Is on. I asked Google Assistant and it turned it off still black lock screen, and cannot turn on dark mode! Please help
Samsung_Moderator
Hey there! I can certainly understand how frustrating it can be when you can't get a feature to do what you want! Let's try to get these working for you.
Here are the steps to turn off the power save mode:
From the home screen, choose Apps.
Choose Settings.
Choose Battery.
Choose the power saving mode you'd like.
Select the switch to turn it on or off.
And below are the steps to turn on dark mode:
Open Settings, tap Display, and then tap Dark Mode Settings.
If you've tried these and your device is still stuck in power saving mode I would suggest having a certified technician take a look at the device!
You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by calling customer support at 1-800-726-7864. For service outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html  I do apologize for any inconvenience.
1 Reply
Samsung_Moderator
Choose Settings.
Choose Battery.
