Problem with phone's settings
(Topic created: 05-03-2022 12:44 AM)
userFJBXLqS7sE
Other Mobile Devices
What's that blue light under my phone's display?
I used to know how to turn it off, (I turned it on myself 😅) but forgot where the setting is.
Here's a screenshot of it. (It's horizontal)
Samsung_Moderator
Hello, thank you for your feedback. I understand how frustrating this can be. I am including a link to a guide to support your concerns on the Edge Lighting Feature https://www.samsung.com/us/support/answer/ANS00077671/#:~:text=Edge%20lighting%20styles&text=the%20l....
JCloud
Notification light. It's called brief pop up setting> then click edge lighting style.
Samsung_Moderator
