useruEu7D9cweA
Problems with battery and brightness bar after latest update on Samsung j6
JUMP TO SOLUTION
Hello. Two days ago I installed the latest update on my j6. I have noticed that the battery drains slightly faster. For 3 hours screen time it now drains 40 percent battery , while before it was around 3o percent.
Also the brightness bar isn't accurate anymore.  The circle appears sometimes at the right end of  the bar  while the actual brightness is low.
As for the layout changes, they are mostly fine, besides where the lock screen now shows the music being played. At the left side rather than in middle. Unnecessary and off putting.
1 SOLUTION
useruEu7D9cweA
Re: Problems with battery and brightness bar after latest update on Samsung j6
JUMP TO SOLUTION
Hello, I did do that the moment you told me.
I had been waiting to reply when i would be sure the battery was working as before.
So far, I believe your answer is the solution. I'm back to charging my phone once a day. All good, thanks.
2 REPLIES 2
JUMP TO SOLUTION
@useruEu7D9cweA Have you tried clearing the cache partition on your phone?
useruEu7D9cweA
JUMP TO SOLUTION
