Ring dumped sound onto phone
(Topic created: 10-05-2023 11:20 AM)
G-dude
Galaxy
Other Mobile Devices
Hello b yall. I'm closing this post because it is blowing up my phone notifications.
VerbumVeritum
Legendary Samsung Care Ambassador
Go to the My Files app>Internal storage>Notifications. The sound files should be located here to remove.
G-dude
Galaxy
I have no idea how/why this happend. 🤷:male_sign:
LongHiker
@G-dude "I have no idea how/why this happend."
Did you install the Ring app? That is how this happened.
If you remove them, your Ring app may stop functioning.
G-dude
Galaxy
I removed the sounds, but the app still works.
VerbumVeritum
Were the notifications successfully removed from the list after you deleted them from the notifications folder?
G-dude
Galaxy
Yes.
VerbumVeritum
Awesome! 🙂
ajanota
Click the -
G-dude
Galaxy
This won't work, it keeps doing it
VerbumVeritum
