voutixtis
Samsung A3 2016 charging issue after Nougat
JUMP TO SOLUTION
Hello everyone,
I recently update my phone SM-A310F to android 7.0 nougat (official update by Samsung).
After the update my phone charges normal until 80% (1-2 hours) from this point and up the charging is getting realy realy slow and its not getting more than 84-86%.  4-6% in 4 hours.
i have already try to:
1.change the charger
2.charge in safe mode
3.charge when phone is turned off
4.clear wipe cashe
5.factory reset
6.update all application
7.turn off the background application in usage
8.turn off wifi-sync-position-bluetooth
9.reduce the brightness of the monitor
10.monitoring the usage of applications
None of theese worked so far.
Any suggestions?
Should i downgrade in previous firmware?
is there any update who can fix this issue?
1 SOLUTION
users7vF01HuO9
Re: Samsung A3 2016 charging issue after Nougat
JUMP TO SOLUTION
the problem solved with the new update by samsung Smiley Happy
13 REPLIES 13
marius_guscia
JUMP TO SOLUTION
I have the very same issue with my A3 2016 (SM-A310F) since today's update to Nougat as well.
userwYqDwTqGqz
JUMP TO SOLUTION
Same problem for me since last night update to Nougat
usergGTkSylb6L
JUMP TO SOLUTION
Same problem here, after update 80% max!
usergBuXrzLEBN
JUMP TO SOLUTION
Same problem for my A3 2016 Smiley Sad Still cant find a solution.
userPDNiMmWzRe
JUMP TO SOLUTION
I contacted samsung for this problem and they informed me that a patch wil be available for download soon, how soon they did not say.
The advise to do nothing...yet
Harry P.
users7vF01HuO9
JUMP TO SOLUTION
exactly the same problem i try all all of these and no solution ...mine not charging up to 86 %
users7vF01HuO9
JUMP TO SOLUTION
Bink86
JUMP TO SOLUTION
I have also the same problem with the model SM-A310F but I still have not received any update.
When checking for updates it says that latest updates are installed and : Current version is A310FXXU3CQH3/A310FVFG3CQH3/A310FXXU3CQH3.
usernkhNTDIVNJ
JUMP TO SOLUTION
Even I update to latest .. My phone is charging very slow. I put over night connected and it's 48% charged till morning. And draining too fast. Please. Help.
