SLR444
- Mute
06-03-2022 12:11 PM in
Other Mobile Devices
Shut down & Restarted
No blue tooth connected
Sound and vibration is on
Not on mute
Each category is checked for sounds to be enabled
Read all the help categories on line
Now what
TIA
Solved! Go to Solution.
NEEMAN_ZACCAI
Comet
- Mute
06-03-2022 12:54 PM (Last edited 06-03-2022 12:57 PM ) in
Open Messenger tap the 3 dots and go into Settings > Notifications > enable Show Notifications and Allow Sound and Vibration. Make sure you enable Show app icon badges, also in the same window go down to Notification Categories > enable new messages .
Now go back to main settings > More Settings > Text and Multimedia Messages and in both of those make sure Show when delivered are enabled. Enabling all of these are necessary bc your phone will likely vibrate or make sound for all kinds of apps and services, so it is a visual verification of messages.
NEEMAN_ZACCAI
Comet
- Mute
SLR444
- Mute
06-03-2022 01:04 PM in
:star:️Thank you! Solved
NEEMAN_ZACCAI
Comet
- Mute
06-03-2022 01:15 PM in
If you could click the 3 dots on original comment and accept solution.
