Showing results forΒ
Search instead forΒ
Did you mean:Β
Highlighted
Samsung Galaxy A70 hot/battery issues
My samsung Galaxy A70 phone is now overheating and the battery decreases. rapidly. I charge my phone to 100% at bedtime and in the morning it's down to 60 in the morning. I'm not sure if it's the phone, battery or that software update. It only starting happening after Samsung updated the phone.😳😑😑
5 REPLIES 5
Highlighted
Re: Samsung Galaxy A70 hot/battery issues
Hello there, could you clarify what you mean by the phone is now overheating? Are you getting an error message?
Be sure to click " βœ“ Accept as Solution" when you find an answer that works for you.
Highlighted
Did you still need help with your issue?
Highlighted
Yes
Highlighted
I charge it to.100% it sits on nightstand and its just starts running hot. Battery loses charge fast
Highlighted
Thanks for reaching out. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
