userPJnx4NvVNp
Samsung Galaxy J7 Audio Jack issues
JUMP TO SOLUTION
For the past two months, I've been having an issue with the audio jack in my phone. When I plug headphones into it and try speaking into the mic, whether during a call, voice message or the voice recorder, nothing gets recorded. I either hear nothing or I hear static from moving the cord around. Initially, I thought it was just the headphones. I went out and bought a new pair, same issue. Plugged both into my laptop and the mic worked perfectly fine on both. I started my phone up in safe mode to see if the issue was with any installed apps but the issue was still there. I've never had an issue with using any kind of headphones with this phone. I've had it for almost two years now and the headphones I'm currently using are the same exact (although newer) headphones I'd bought and used for months the first year I got the phone.
1 SOLUTION
Honored Contributor
Re: Samsung Galaxy J7 Audio Jack issues
JUMP TO SOLUTION
In that case, definitely reach out to Samsung directly via Phone (1-800-726-7864) to set up an evaluation and repair. Naturally you can also reach out to your carrier to see if they have a different option you might like more or maybe someone here in the Community has some other ideas!
25 REPLIES 25
Honored Contributor
JUMP TO SOLUTION
Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know!  Smiley Happy
userTz1LuYjVBy
JUMP TO SOLUTION
Yes , i too had the same issueess
userz2d2YSWw8w
JUMP TO SOLUTION
Yeah, i also have the same problem .. how to repair this ????
userd31nizXfAb
JUMP TO SOLUTION
Yes. My jack stopped working on my J7. I tried cleaning it and restarting the phone. The haedphones and earbud work fine on my other devices.
Honored Contributor
JUMP TO SOLUTION
@userPJnx4NvVNp
Other than Safe Mode and a different set of headphones, have you tried any troubleshooting steps?
userPJnx4NvVNp
JUMP TO SOLUTION
Like what?
Honored Contributor
JUMP TO SOLUTION
Let's try some troubleshooting steps, just let me know how these go!
  1. Are all your Apps are up to date? You have 2 places that you need to look. Google Play store and Galaxy app store. Go to both and check My Apps. Make sure there is no app that needs updating.
  2. Is your phone OS up to date? Go to Settings, About phone and check for software update. Make sure you have the latest phone software.
  3. Clear phone cache. Instructions are here
  4. Restart your phone in Safe mode. This is just to help you isolate the issue if it is caused by 3rd part apps. Instructions are here
userOgQflyc7Px
JUMP TO SOLUTION
Did that on my Sj7 star, I also tried a variety of different kinds of product & none of which work. It is so frustrating since now I am stuck with the problem & my phone. It's just a day after warranty expired u find out it's an issue with this phone. Had I known I would have taken it in but I just started to attempt using the headphone jack a week ago for use on my car stereo that doesn't have bluetooth.  My phone has all my songs & now is useless to listen to. Oh I know it has that special little speaker but I want bass.
userd31nizXfAb
JUMP TO SOLUTION
I am logged in but everytime I try to access the links in your solution post I get a red flag indicating I am not authorized to open the page. I have an account and am paying for this phone! How is it I am not authorized to view the linked instructions to solve my device issues?
