Highlighted
Samsung says my battery is draining faster than its charging.
JUMP TO SOLUTION
Help? I'm not sure how to fix it. First post here, also.
1 SOLUTION
Highlighted
Cosmic Ray
Re: Samsung says my battery is draining faster than its charging.
JUMP TO SOLUTION
Have you tried multiple chargers? Have you tried turning your phone off and seeing how long till full charge?
3 REPLIES 3
Highlighted
Cosmic Ray
JUMP TO SOLUTION
Highlighted
Halo
JUMP TO SOLUTION
Don't use your phone while charging, also try power saving modes
Highlighted
Samsung Care Ambassador
JUMP TO SOLUTION
This occurs when a power supply can feed the device connected. So if the host is using 1500mA and the supply can manage only 1000mA, the device will continue to drain. In this case you ought to try another USB cable, along with wall adapter.
If my reply has aided your issue please consider liking it. If the problem is solved you may pick it as a solution.
