Solar Remote Charging Issues
(Topic created: 11-06-2023 04:31 AM)
PatAt
A Series & Other Mobile
My solar remote has to be charged every night to be able to use it for 3-4 hours
Patat
JBTechfanatic
Black Hole
So it says fully charged but doesn't work? Or it's says fully charged then dies? If it says fully charged nut doesn't work use the resync option I stated above. If not call Samsung and ket them know it's defective and under warranty. I would assume they will send you one once you registered and provide proof of purchase. To activate the warranty.
JBTechfanatic
Black Hole
Try using a USB type-c charger and charge it to full. Next resync the remote Next, press and hold the Return and Play/Pause buttons simultaneously for at least 3 seconds. Your TV will begin syncing with the Smart Remote. It hopefully now will last you for months like mine does. Be sure the buttons are not being held down in a drawer or anything during storage.
PatAt
Hi Supernova,  I always use a USB charger to which it’s left connected for around 20hours per day.  The TV shows it to be fully charged.  The TV and remote is only 3 months old.  We thought it would improve but it seems not,
JBTechfanatic
Black Hole
PatAt
Hi it shows fully charged but loses around 10% per hour.
JBTechfanatic
Black Hole
Definitely call it might just be a bad battery. I have many many one remotes and they last for months. So I would guess it's a bad battery. If you have already resynced it.
PatAt
Hi JB there is a little problem with calling as I live in Spain.
Regards
Pat
JBTechfanatic
Black Hole
