ShaunH
- Mute
β03-26-2023 03:03 AM in
Other Mobile Devices
When adjusting volume for system siund notification it clicks sounds instead of media then when adjustion vibration of noitifications it shiws Touch insensity which is also under the other Vibration /sound setting for that category. But i do get system sound and vibration and sound when i charge my phone since i chose to toggle that on! This whiole phone messed up alreafy been posting about other issues with tjis phone on other threads. Check it out if this stuff hapoens to you. Ssmsung and Googke dont reply or give feedbacack. Samsung Members shows my phone not registred but out of warrsnty so was registered at one time when i got this A12 my only device in July 3032! So how did it get unregisteted?
1 Reply
- Mute
β03-29-2023 10:20 AM in
Other Mobile DevicesHi ShaunH, thank you for reaching out. I can certainly understand your frustration in regards to settings being set up not to your liking. Thankfully, you can roll those back to their defaults by going to Settings > General management > Reset > Reset all settings. This won't delete data, so don't worry! It will only set certain settings such as the vibration and sound back to their defaults.
