Sound problem Samsung Galaxy A8 2018
(Topic created on: 3/20/18 3:18 AM)
Flavi Morosan
Other Mobile Devices
Hello guys.
Recently, I bought a new Samsung Galaxy A8 2018, and since I updated the android, I have sound prolem, like static sound and distorted sound. It happens almost every time is listen to music or watch a video on YouTube or Google.
I booted the phone in SafeMode, to see if there is an app that is causing this problem, but the sound distortion and the static sound is still there.
I even made a factory reset, but with no success.
Any idea for the fix?
I have the warranty, so I should send the phone to service or wait for a new update for the android?
Thx guys!
JUMP TO SOLUTION
uservyuBEikB5O
Same problem here! It has happened since the beginning, and everytime I reproduce audio over the main speaker (not over the headphones jack or over bluetooth).
Did the OTA software update two days ago, but the issue is still there.
I've had my phone for two weeks, and would be happy with it had it not been for this, but it's a major issue and not acceptable.
Has anyone found a solution? If it's a HW problem, can Samsung fix it without affecting the IP68 (waterproof) capabilities?
usernEX5yvlMTl
I observed that this problem appeared at my phone with July update, when introduced the Dolby atmos feature...I don't know if bootloader let me downgrade to June firmware,now, when I just installed the October update.I guess Dolby atmos feature make this problem...
Makiem
1st October update - no fix. I've given up. Thanks Samsung, I've learned my lesson. I had Samsung midrange led TV give me troubles after year and half, now midrange smartphone. Poor QC, I'll try my luck with new companies that have something to prove and win customers over.
We shall see how long can you make money off of old glory and brand name.
user4e37v2Ie2K
I have exactly the same problem guys!
userHf4UNtrL5Z
Same here. When a notification arrives and the notification sound will skip a tone (like the sound dong-dang and it turns out ...-dang). Not only this bothering me, when I use the samsung keyboard with the typing sound on, the sound will also failed to catch up. I hope it just a software problem.
echo26
same to me. this happens clearly after i running a game with game launcher in high performance, the sound skipping in frequently. i think it just the game but apparently my notification sound goes skipping too. after i restart my phone and i played a music, the skipping seems reduced
userJYIzTiglEY
I have the exact same problem. The key board sounds don't work and when I'm watching YouTube or Netflix it cuts out
userC7UytlmgWw
Same problem, bought in Hungary, after 1 hour of starting it up, the issues began. It is crazy that there is still no solution to this after all this time.
Wiacnuqas98
Hello guys
I'll try to help
Here the solution
1.Change sound mode to vibrate or silent. If this not work try :
2.Restart your device.
Option 1 work for me
Thanks guys cmiiw
user6BgsQEYu9c
did any one found a solution..
wow this seems to be a common problem and this phone is new..i think samsung should make a software update soon to resolve the problem..
