Highlighted
System notification sound
My son has a unrooted Samsung J2-pro with androud 7. A third party app that I've uninstalled already, has changed the "system" notification sound to a silly song. I mean the notification that plays when I am receiving sth over wifi-direct (not the default notification of message or call). Any idea how to get rid of it without factory reset? Any help will be highly appreciated.
2 REPLIES 2
Highlighted
Re: System notification sound
Please boot into Safe Mode and then try uninstalling the app.
  1. With the device switched on, hold down the Power button until the SAMSUNG Galaxy J2 Pro SM-J210F options appears on the screen.
  2. From the following menu tap Restart two times.
  3. While the phone is restarting press and hold the Volume Down button for a while.
  4. You can release the Volume Down when your phone is turned on again.
  5. You should see the Safe Mode logo in the left-down corner of the screen.
To exit Safe Mode, simply reboot the device.
Highlighted
Hi, thanks for rapid respinse.
As mentioned already, the bad application has been uninstalled already and when I rebooted in safe-mode, I saw nothing relevant to that app to uninstall. The app has copied the audio file somewhere in system folders, I think.
