Verbal message indicating Battery level at 50 %, 40% ...
(Topic created: 09-06-2021 12:19 PM)
Centri125
Other Mobile Devices
In the Status Bar I have showing let's say 75% for the battery level.  However, each night around 8:30 PM, I can hear from my mobile  a voice saying your battery level is at 50 % and 30 minutes later or so it is at 40% and so on.   I do not have any Bixby routine set up.   I am lost as to why the voice says a number when in fact in the Staus bar the the number is different.  I have a Samsung Galaxy A71 with Android 11 and One UI version.  Thanks for your help.
1 Reply
SamsungQue
I can see how this issue could frustrating. Have you made sure that your phone is up to date on its software? When it says your phone is at 50% is your phone actually at 50%? Does this issue still occur when your phone is in safe mode? Have you made sure your Bixby routines are set to off? Here is a link to help you check. (https://www.samsung.com/levant/support/mobile-devices/how-to-use-bixby-routines/)
