Wireless Andriod Auto on Suburu not working
(Topic created: 04-17-2023 06:25 PM)
Sapman
Other Mobile Devices
Does anyone know if wireless android auto works on a 2022 Forester? I've tried to make it work with no luck.
Sapman
Thank you. I did some further research an wireless android auto is not a feature on the Forester.
JMSmucker
I don't own a Forester, so I can't speak from experience, but based on their website, it looks like it's Bluetooth wireless only. Most likely you'll still need a cable to connect to your car.
Motorola does make an adapter for wireless Android auto, in case that's a must-have feature for you.
Sapman
