rruaboiero
replacement battery for samsung galaxy j700 model code EB-BJ700CBE
JUMP TO SOLUTION
I'm trying to know if the battery with model code EB-BJ700CBE is compatible with galaxy j700 and j400 models (both require a 3000mah battery). Up to now, nobody from Samsung support and several Samsung store dealers could give me a simple and straight forward answer. My issue is that I have a galaxy j400m and I need a spare battery for my travels. I'll appreciate anyone who can give an answer or a tip / hint to look forward.
1 SOLUTION
Re: replacement battery for samsung galaxy j700 model code EB-BJ700CBE
JUMP TO SOLUTION
I recommend reaching out to Samsung Parts. They can be reached at 1-800-627-4368 or on samsungparts.com.
4 REPLIES 4
JUMP TO SOLUTION
rruaboiero
JUMP TO SOLUTION
thank you Larry, no available information in their website, I'll try by phone though, and i'll get back to you if I have an answer.
JUMP TO SOLUTION
Great. Keep us posted!
rruaboiero
JUMP TO SOLUTION
They've already give me an answer, thank you again for your help!
