Highlighted
samsung a10s power key not functioning
my mobile a10s device's pwer key has recently become very hard to use. i have press it with alot of force to  sleep off the device or turnung it off. there is physical damage on the key that i know of  .
1 REPLY 1
Highlighted
Re: samsung a10s power key not functioning
Just to clarify, you stated there is physical damage on that key is that correct?
