Help!! 50 Inch Class Crystal UHD CU8000
(Topic created: 4 weeks ago)
Velvet702
Projectors & Other TVs
50 Inch Class Crystal UHD CU8000 is not working. I had it connected to my Xbox while I was gaming. But from the bottom right corner a black shadow appeared and then covered the entire screen. It slowly blinks are dark black screen then a lighter screen. I can't use the remote because nothing shows up. I unplugged it and then held the power button to clear out any power left in it. Still nothing. Can I fix this or do I need to just buy another tv?
1 Reply
MrGhoul
Black Hole
You could have the tv looked at by a professional, but from my experience, i think it may be time to purchase a new TV.
Service locations
https://www.samsung.com/us/support/service/locations/
