NoName1904
- Mute
03-09-2025
05:19 AM
(Last edited
03-11-2025
05:49 PM
by
SamsungCaleb
) in
Hello I am inquiring on some help in seeking a sound bar with good quality for my now Samsung Q60T (58") TV. It is a 2020 model. Any suggestions on what to look for in simplicity of use, good sound quality, and options to look for in making a selection for this equipment? Please advise.
Solved! Go to Solution.
JBTechfanatic
Black Hole
- Mute
03-13-2025 10:16 PM in
QLED and The Frame TVs
Yes, absolutely. Going with a Samsung 5.1 or better surround sound soundbar system—Samsung to Samsung—will give you an easy-to-use, great-sounding combo with special Samsung-to-Samsung-only features. The question is, what is your budget? I can then recommend one.
1 Reply
JBTechfanatic
Black Hole
- Mute
