Frame TV Model: QN55L03TAFXZA
(Topic created: 01-08-2026 09:57 PM)
Adeel_Ahmed
QLED and The Frame TVs
Hi, i would like to know  what models of One Connect Box are compatible with the Frame TV Model: QN55L03TAFXZA. Thanks
1 Reply
SamsungDarius
Hello Adeel_Ahmed, thank you for reaching out to the Samsung Community. Regarding your question about the One Connect Box for the QN55LS03TAFXZA model, this specific model number is not a US-region model; it is primarily associated with the Canadian and Caribbean support. Because our support tools are tailored to US-specific hardware, our information on this exact inquiry is limited.
Unfortunately, I was not able to locate this specific TV in our system. However, I can help point you in the right direction to locate this information. If you open the user manual in the link and perform a word search, you should be able to locate the proper One Connect Box for your Frame TV.
QN55L03TAFXZA Frame TV User manual Link
You can also try reaching out to the support dedicated to this model by going to the link here: https://www.samsung.com/latin_en/support/model/QN55LS03DAFXZA/
There isn't any model with QN55L03TAFXZA
