Frame TV and Xfinity Stream issues
(Topic created: 11-08-2025 01:56 PM)
Ksicecream
QLED and The Frame TVs
Any suggestions on how to resolve constant connectivity issues with Xfinity Stream? We bought it to get rid of the box and we have had chronic issues ever since. Xfinity blames Samsung frame OS.
CEParsons
Black Hole
If the XFinity app for Tizen (Samsung TV OS) isnt working properly, that would fall back on Xfinity's devs needing to fix the issue.
If you want an immediate solution rather than waiting on Xfinity to update and fix errors with the app, you may consider connecting the Xfinity box to your OneConnect box. Alternatively, do the same with a third party streamers such as a Google TV box with a (hopefully) better supported app.
Robin621k
Honored Contributor
Google TV is much better with updating apps, as the apps come from the Playstore!
