- Mute
Sunday
(Last edited
Wednesday
by
SamsungMatt
) in
The picture and broadcast options from my settings are greyed out. I had wanted to rescan as local stations have changed their antenna channels.
- Mute
Sunday in
QLED and The Frame TVs- Mark as New
- Mute
Sunday in
- Mute
Tuesday in
QLED and The Frame TVsHello @ghwmd1, welcome back to the Samsung Community! Thanks for reaching out. To help us look into this issue further, could you please provide the full model number of your Frame TV?
- Mute
Tuesday
(Last edited
Wednesday
by
SamsungMatt
) in
QN55LS03RAFXZA
- Mute
Wednesday in
QLED and The Frame TVs@ghwmd1 Thanks for sharing your model number! Letโs try a couple of quick things to see whatโs going on:
Close background apps
Press and hold the Back/Return button on your remote for about 2โ3 seconds. That should close anything running in the background.
Doubleโcheck your input
Make sure the TV is set to the โTVโ input and not HDMI or another source.
Check your coax cable
Just take a moment to make sure the coax cable is firmly connected on both ends.
If none of that helps, the next step would be a soft reset:
Soft Reset
Press and hold the Power button on your remote for about 15 seconds until the TV restarts. After it boots back up, see if the settings show up again.
Please let us know if this helps!
- Mute
Wednesday in
QLED and The Frame TVs@ghwmd1, let's give a Hard Reset a try.
Locate the Power and Volume Down buttons on the TV.
Press and hold both buttons at the same time.
Wait for the TV to begin the reset process.
Do not unplug the TV during the reset.
Additional Notes:
All downloaded apps and accounts will be removed.
Network settings may remain unchanged.
If the reset option is unavailable, exit any open apps and try again.
If all the previous troubleshooting steps end up being unsuccessful in resolving this matter, we are next recommending service. You can seek service via our phone support at 1-800-SAMSUNG (726-7864) or contact a moderator by Private Message with the following details, so we can review any service options available:
Full model number
Serial number
Name
Address
Phone number
