JP_004
- Mute
a month ago in
QLED and The Frame TVs
I have two Samsung QLED TVs that are used daily. I have Anker Soundcore Liberty 4 Pro wireless earbuds which I use on both TVs, almost daily. I went to sit down and watch a show (Netflix) last night with my earbuds connected as normal, except now, when I adjust the volume using the remote, there are no longer volume numbers to indicate the level, and I can only increase the volume to a certain point (which is not loud enough). It can be decreased but will not go above this volume level (there is no indication of what volume it is on, it sounds like 50% of what I would normally have it on). Again, the volume numbers are gone and it only shows + and - for volume on both TVs, does anyone know a fix for this?
