Missing C1 Screws in Slim wall mount for Frame TV 43 INCH
(Topic created: 04-05-2025 05:50 PM)
drsandykalra
QLED and The Frame TVs
Hello,
I was installing the frame 43-inch TV with slim wall mount, when I was almost done and just needed to screw in C1 screws in TV, I found out that the screws are thicker than the holes they are supposed to go in. Can Samsung send me the C1 screws for 43-inch TV? It's frustrating to leave the installation in the middle, I can't even take out the wall piece and can't even hang the TV.
Need urgent help.
Thanks
Contact Samsung Support to request the C1 screws.
1 Reply
