- Mute
ā06-08-2025
09:39 AM
(Last edited
ā06-12-2025
01:44 PM
by
SamsungCaleb
) in
Good morning. I have a 55" Q8DT, Model QN55Q8DTAFXZA. I purchased a new Nintendo Switch 2 and have everything hooked up fine. However there is an HDR adjustment setting through the Switch that lets you calibrate according to 2 images. One will white out with a slider while the other remains visible. However when trying to adjust no matter what I do I cannot get that to not white out both simultaneously.
I spoke with Nintendo and Samsung this morning besides searching the web. A couple of suggestions that were recommended are not options on my model. I was told to go into Expert Picture Settings and change 'Dynamic Tone Mapping' and or "HDR Tone Mapping' to off and enable 'HGIG' on the unit.
The pictures menu does not have any option for tone mapping much less any HDR settings even in expert. It does have a listing for HGIG and that is on. But the calibration still whites out most images.
Nintendo had no answers. After being on the line with the Samsung tech he checked the specs and said with the HGIG my unit does not have any option to change the HDR setting and it is set at maximum by the TV itself with no way to adjust.
Any thoughts would be appreciated.
- Mute
ā06-08-2025 10:58 AM in
QLED and The Frame TVs- Mark as New
- Mute
ā06-08-2025 11:22 AM in
QLED and The Frame TVsThank you for responding. I already had input plus applied to the port the Switch 2 is on. I put the tv and made sure wifi was corrected. Switch on, HDMI removed, waited one minute and then plugged HDMI back in. It did not recognize my Switch 2 as a console but as an unknown. But the first time it ever was plugged in it did recognize it. Same with my Fire TF 4K, first time I plugged it in the icon came up but since then anytime I would have to remove it and plug the HDMI back in it comes up as an unknown device.
I do have game mode set to automatic so whenever I turn the Switch 2 on it changes to game mode. I have also tried with game mode on all the time on the Switch port instead of auto. I went through all the settings on this before as well as game mode plus. Tried with HGIG on and off. Went to the calibration and the same issue, both icons whited out when set at the top setting.
- Mute
ā06-08-2025 11:37 AM (Last edited ā06-08-2025 11:39 AM ) in
- Mute
ā06-08-2025 11:43 AM in
- Mute
ā06-08-2025 11:44 AM in
- Mute
ā06-09-2025 09:56 AM in
QLED and The Frame TVsYeah same issue as me. Both suns disappear at the same time and the q80t doesn't have an option to turn off dynamic tone mapping. Plus the tv doesn't recognise the switch 2 as a gamingdevice like my ps5 etc
- Mute
ā06-09-2025 10:21 AM in
- Mute
ā06-15-2025 11:53 PM (Last edited ā06-15-2025 11:55 PM ) in
QLED and The Frame TVsI have it on hdmi 1 I think, but didn't show anything. Haven't tried it on the "gaming" appropriate source. Yeah it starts with both suns barely showing. My calibration is left sun black and the moment it switches to "grey" I stop the calibration, because when both are close to white the colors are washed out.
- Mute
ā06-16-2025 10:14 AM in
QLED and The Frame TVsHey mate. Check your settings because I also have a Q80T and it does recognise my Switch 2 as a console. I do however have the same issue with HDR
