QN90C Neo QLED 4K USB power settings?
(Topic created: 04-28-2025 06:06 PM)
jack0194
QLED and The Frame TVs
Hi,
I'm not sure whether this is even possible but is there any way to change the USB power settings, so they don't turn off when the TV gets turned off?
I'm playing around with a Fire stick 4k at the moment (Trying to fix) and it is apparently better to have constant power, so it works better. I'm also thinking of getting the Google tv Streamer 4k down the track.
GaryB82
Galactic Samsung Care Ambassador
I don’t think they can be changed to provide power continuously.  If I remember correctly doesn’t the fire stick plug in to a wall outlet with the provided power brick same as Google streamer all plug directly into a wall outlet for direct power.
Edit: Yeah the Firestick comes with a power brick to plug directly into a wall outlet for continuous power
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
jack0194
This is the standard power set up. There is a product that came out in 2020 that allows you to power via USB: Amazon.com: Made for Amazon, USB Power Cable (Eliminates the Need for AC Adapter) : Amazon Devices &...
And it works but it's hard to tell what the difference is like. I got it when I got mine. There is one for Google tv streamer 4k but so far this isn't even available where I am and it's still so new that no one really can see how this would work.
