Samsung un55ru7100f will not connect to Bluetooth
(Topic created: a month ago)
thomnic52
QLED and The Frame TVs
Cannot connect to Bluetooth soundbar.  When I go to Bluetooth Speaker List it begins to search, but cannot find any device.  Bluetooth speaker is just below TV.  Tried soft reset no luck, software update - no luck.  What do I need to do next?
Samsung_Moderator
Hi, thomnic52, Thank you for following up that the TV is not connecting to any Bluetooth device.
We show that your initial concern was that the soundbar isn't connecting via Bluetooth. We would recommend connecting the soundbar to the TV via a high-speed HDMI cable with Ethernet support on the ARC/eARC ports for both the TV and the sound bar if that option is available for your sound bar.
As far as the Bluetooth not working, the steps provided will normally resolve the Bluetooth connection issue, but since the TV is still not connecting to Bluetooth, service would be necessary.
To set up a service, please reach out to Samsung with one of the options below.
Online at https://www.samsung.com/us/support/service/
Contacting Customer Support at 1-800-Samsung (1-800-726-7864)
Contacting a Moderator through Private Message
Please have this information handy when requesting service:
Model Number
Serial Number
First and Last Name
Best Contact phone number
Address where the unit is located
Email address
qzrl
Halo
Try contacting Samsung support, they are the experts. https://www.samsung.com/us/support/
Samsung_Moderator
Hello thomnic52, thank you for reaching out to our Samsung Community regarding your Bluetooth connectivity concerns, and we'd love to assist you with getting this resolved. We'd like to verify that you have the SmartThings app downloaded on your mobile device and the soundbar/TV is on the same network?
We also recommend for you to review the following articles for assistance:
*This article is to further assist with connecting a Bluetooth device: https://www.samsung.com/us/support/answer/ANS10006960/
*This article is for assistance with setting up a Samsung soundbar: https://www.samsung.com/us/support/answer/ANS10005242/
thomnic52
I have followed all the instructions and TV just will not connect to any Bluetooth item.
commumityhelper
Cosmic Ray
The Bluetooth speaker is on right?
thomnic52
Yes, and I have tried other Bluetooth items (hearing aids, headphones) and nothing connects.  TV just searches and returns the message "no items found".
Samsung_Moderator
thomnic52, we appreciate you being as accurate as possible and suggest that you may want to just do a factory reset and start over as a final option. You can review our article here, https://www.samsung.com/us/support/answer/ANS10005248/, and please keep in mind after performing a reset on the TV, you will need to sign back into your apps.
thomnic52
done the reset with no change in results
Samsung_Moderator
Model Number
Serial Number
First and Last Name
Email address
commumityhelper
Cosmic Ray
On this app go use the diagnostic test in service
