Sound issues with Samsung QA85QN90
(Topic created: 04-28-2025 02:46 AM)
PeteRep
QLED and The Frame TVs
4 months after purchasing my 85 inch QLED, I started having sound issues. I play my audio through the TV speakers as it has Dolby ATMOS. The sound it normally brings out becomes stereo sounding and very low. Sometimes resetting the tv works but that may also take up to the 5th attempt which shouldn't be normal. All diagnostic tests get run and sometimes it stays as a low stereo sound. Does anyone else have this issue? If so how is it fixed? I don't think it's a settings issue as it goes from normal sounding speakers to an antique portable radio.
Samsung_Moderator
Thank you so much for reaching out! This forum is for the support of US products and customers. We do not have the ability to support models outside of the US. There are differences between the US and International firmware, which we do not have access to. Since your product was purchased outside of the US, please visit the link below for support in your area. https://www.samsung.com/us/common/visitlocationsite.html
1 Reply
Samsung_Moderator
