USB PORTS POWER?
(Topic created: 12-21-2024 01:47 PM)
Members_1CcVrM2
QLED and The Frame TVs
I have a brand new NEO QLED QN80D TV.  I have some LED lights plugged into the USB port in the back of the TV.  When I turn off the TV the lights do not turn off.  Last night the lights stayed on until I unplugged the USB port in the morning.  I tried looking for some setting under system in the power section but I did not see one.  I like the lights in the back of the TV but don't want to leave them on all the time.  It would be nice if they turned off when I turned off the TV.   Thanks for your help.
That is intended. The udb is for samsung accessories such as the z wave dongle. Or for steaming sticks. I wouldn't use it for led straps as you could over time damage the power board for TV. Just buy a 25w power brick and a govee smart plug. Set it to a schedule or manually turn it on and off the govee app.
1 Reply
