Wall Mount Frame Pro
(Topic created: 06-28-2025 06:14 PM)
Mark17
QLED and The Frame TVs
2025 65” frame Pro
Best Buy install team informed my wife there would be a wire to the 1 connect box. Install was canceled. They also informed Wife the recessed wall box on tiled wall with 2 electrical outlets, cable and data port is not adequate. The wall mount is also Samsung. What am I missing??
thanks in advance! Mark
GaryB82
Galactic Samsung Care Ambassador
Normally people have a recessed box that is bigger so the one connect box can be mounted behind the tv or they have a recessed box that has a tube that runs down inside the wall so the one connect box can be located in a cabinet below the tv so you don’t see the wire.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
1 Reply
GaryB82
