Wireless One Connect Box not connecting
(Topic created: 07-22-2025 07:17 AM)
ArtDecoMKE
QLED and The Frame TVs
My new Frame Pro cannot see the Wireless One Connect Box. I have done lots of searching online, spoken twice to Samsung Tech Pros (they clearly did not know the product, one insisting that my TV would not work without the One Connect box being connected). I am not getting any response from the Text access, which tells me they’ll connect me right now to a Tech Pro - no response at all after that.
The One Connect box shows only a white light on the side. Not matter what I do, it only shows white, not blue or even Red or Orange. (It has been reset multiple times, and I’ve gone through all the plug and unplug suggestions.) It seems the box is the fault. How do I get better access to tech support to get this thing replaced?
Samsung_Moderator
Hello! Thank you for reaching out! Unfortunately, I do not see a way to reset the One Connect itself as I am aware that it does reset once it connects to the TV and you do a factory reset after it is connected. The only option would be to get a new one connect. But as far as I am aware service would be the only way to get a new one. Please feel free to send a private message to me or any of the other moderators with your full model number and serial number, as well as the following information.
Place of purchase:
First and Last Name:
Physical Street Address:
City, State, and Zip Code:
Home phone number:
Alternate phone number:
Email address:
GaryB82
Galactic Samsung Care Ambassador
What’s the model number of the TV. I didn’t even know they had a wireless one connect box on the new tv’s
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
ArtDecoMKE
This the Frame Pro 65” LS03FWD. It has a wireless One Connect box, and the TV itself has near full fuctionality with the Tizen OS.
ArtDecoMKE
Can I get a @SamsungModerator To respond to this issue?
GaryB82
I’m still trying to determine the cause of the problem, but perhaps a moderator could help.
@SamsungCaleb
ArtDecoMKE
There are plenty of examples found online of people reporting that their box is not functioning and those are being replaced. As I mentioned the TV itself works just fine, and apparently the box is mostly serving as a hub and a few other things.
Samsung_Moderator
Place of purchase:
Home phone number:
Email address:
