CC problem
(Topic created: 10-19-2023 11:30 AM)
DieselDoc
QLED and The Frame
Cc stops working, says it's on, must unplug tv to get it working again. May work day or 2 then must unplug again.
Samsung_Moderator
QLED and The Frame
Hello! Thank you so much for posting about this. I completely understand your concerns with the closed captioning working on and off. I'll be more than delighted to assist you with this issue. Navigate to Menu, then select Settings, and select Support. Select Software Update, and then select Update Now.
Also, you can Factory Reset the tv as well. Here's a link you might find helpful: https://www.samsung.com/us/support/answer/ANS00077524/
If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this on a case-by-case basis, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
1 Reply
Samsung_Moderator
QLED and The Frame
