Frame 2022 audio delay
(Topic created: 08-07-2022 10:31 PM)
uservpYD6HNeLN
QLED and The Frame
I have a brand new 75” Frame 2022 and the audio keeps falling out of sync. Pausing the program will fix it temporarily, but within 3-5 minutes it is out of sync again. Happens in Netflix and Hulu.
Using built in speakers, nothing else
I have seen others post with this same issue without any reasonable resolution.
Diaboyos
Neutron Star
QLED and The Frame
TV's aren't really built to stream. They sell smart TV's but dedicated streaming devices will usually always work better. Look into a roku or if you want better an Nvidia Shield.
QLED and The Frame
I have the '22 Frame as well but don't see any audio delay while streaming Netflix and Hulu apps. How often does it happen? Is your TV firmware up to date?
iandeboisblanc
QLED and The Frame
Same issue. Audio sync gets worse and worse over time until its off by a full second or more. Pausing fixes it.
