Frame Tv: Art Mode Sleep Mode missing Options
(Topic created: 01-26-2024 11:39 AM)
Rogier Festen
Cosmic Ray
QLED and The Frame
Since I purchased my the frame 2023 model 55inch this design wise beautiful tv has been a software/ firmware horror. And samsung support although friendly does not live up to their promiss to have a product expert call me back.
never in my life I would have expected resetting my TV to factory defaults once a month to keep the art mode sleep working.
but now I have a new issue, even after a factory defaults reset on firmware 1602 the Art Sleep options menu is completely EMPTY only a close button appears, resetted the device 3 times in a row but can’t get it work again.
effectively a useless product now.
Samsung please pick up your responsiblity and fix the crapy firmware.
and really after all the hours that I have spend trying to resolve the issues of the worthless product… I really can tell.
Kieran O
QLED and The Frame
We’re experiencing the exact same issue on the 55” 2022 model. It’s extremely frustrating! Responding in the hopes it gives the post more attention
Rogier Festen
Cosmic Ray
QLED and The Frame
Thanks for your support and reply, lets hope we can attract some attention of Samsung Devs.
regards R
Nic0las
QLED and The Frame
The same problem for my 75" 2023 Frame bought this week. I contacted Samsung support by phone and they were unable to fix it.
Rogier Festen
Cosmic Ray
QLED and The Frame
Thanks for your reply and support to this topic NicOlas, may I ask what you agreed as next step with Samsung Support?
Dennisc1988
QLED and The Frame
Same here
Rogier Festen
Cosmic Ray
QLED and The Frame
Thanks for sharing Dennisc1988. @userKHUJBda323fv please take a look at this topic!
jgg53
QLED and The Frame
Same problem on 43" Frame bought this week. A solid bug
(However I managed to get to the sleep options settings in the smart things app)
Rogier Festen
Cosmic Ray
QLED and The Frame
Indeed you are right, the setting are in the smart things app. Lets see if my screen art display functions again.
Rogier Festen
Cosmic Ray
QLED and The Frame
Thanks for your support and reply jgg53, let me test that as well, btw normally I do not use that app.
