Less than 2 months old QN85BD - No Network Cable Detected
(Topic created: 02-09-2023 06:03 PM)
usereuvdODG1ri
Cosmic Ray
QLED and The Frame
Greetings,
QN85BD, less than 2 months old, was connected to ethernet cable since day one and worked perfectly fine.
Today, all of a sudden - No Network Cable Detected.
I checked several different cables - they all work with other devices but the TV, so it is not an ethernet cable issue.
Sure, I can work off wifi but I don't want to. I paid a lot of money for a TV with ethernet port and I should be able to use it.
Any one else experiencing the same issue and/or know how to fix this?
Thanks.
IRStaten
Comet
QLED and The Frame
I'd contact Samsung for a home repair.
IRStaten
Comet
QLED and The Frame
usereuvdODG1ri
Cosmic Ray
QLED and The Frame
I "hard-rebooted" the TV and surprsingly it is working again. Not sure what's the scoop with this but I will certainly do so if it keeps happening.
I am just curious if anyone else experience this problem. I read many occurances that were reported  2-3 (and more) years ago, so this is kind of a "known issue" with Samsung TV, one would assume that Samsung took care of the problem.
