Light Guide Plate replacement part for 85" QLED
(Topic created: 12-02-2023 08:29 AM)
ares614
QLED and The Frame
I'm looking for a replacement part for my SAMSUNG 85" QLED QN85 Q70 (Model#: QN85Q70AAFXZA).
I think it's called a light guide plate (aka LGP); which carries the edge-lit LEDs up to the top of the box to fully illuminate the LCD screen.
Can someone point me in the right direction of where I can buy one for this tv set?
Samsung_Moderator
QLED and The Frame
Hi there, Thanks so much for asking about this. We recommend checking with our parts department for any needed parts and accessories. You can find them online at SamsungParts.com or by calling 1-800-627-4368. Alternatively, you can use the link below to locate a service center in your area to assist with the repair.
https://www.samsung.com/us/support/service/locations/
1 Reply
Samsung_Moderator
QLED and The Frame
