userDDoMMTtBEQ
- Mute
01-08-2022 10:08 AM in
QLED and The FrameI ordered a 43” Frame TV and the wall mount is missing. How can I get Samsung to send me the mount?
Solved! Go to Solution.
- Mute
01-08-2022 12:09 PM in
QLED and The FrameHello! to purchase any parts I recommend reaching out to our part distributor, J & J Parts, at 800-627-4368 or samsungparts.com
1 Reply
- Mute
