- Mute
10-17-2022 12:59 PM in
QLED and The FrameI just got 55 inch The Frame, 2022 model. it's mounted on the wall with teak frame.
If I take the bottom piece of the frame off the motion sensor works as intended. The art mode shuts off when there's no motion and turns automatically back on from motion. The night mode is turned off.
When I install the bottom piece back the motion sensor doesn't work at all. The art mode stays on even when there's no motion for hours (sleep after is 5 minutes).
I've now tested dozens of times with and without the bottom frame piece and the result is consistent. With the frame it doesn't work and without the frame it works.
Any suggestions how to fix it? Has anyone had better luck with different color frame than teak?
- Tags:
- frame
- motion sensor
- Mute
10-17-2022 01:25 PM in
QLED and The Frame- Mark as New
- Mute
10-17-2022 01:49 PM in
QLED and The FrameNot sure if it's the same for the 2022 model, but on the 2020 model, which I have, there's a little clip on the motions sensor. When pressed in, the motion sensor will extend downwards a little bit. Making it better in detecting motion.
- Mute
12-24-2022 02:20 PM in
QLED and The FrameSame issue. This is so silly. Mine doesn’t extend down any further.
- Mute
a month ago in
QLED and The FrameSame Problem here with 43" and teak bezel!!!! There´s also a new tread with the same Problem.
- Mute
3 weeks ago in
QLED and The FrameSame issue here with the 55 inch and the teak bezel. Repeatably getting this behaviour
- Mute
3 weeks ago in
QLED and The FrameExact same issue here with teak frame
- Mute
3 weeks ago in
QLED and The FrameSame issue here on 85 inch frame tv. Replaced white bezel with teak and now motion sensing isn’t working. Where is Samsung on this?
- Mute
2 weeks ago in
QLED and The Frame"Replaced white bezel with teak and now motion sensing isn’t working."
That's so weird! It worked with the white bezel, but not the teak one?
- Mute
a week ago in
QLED and The Frame
