Need help finding one connect cable bn68
(Topic created: 07-18-2023 01:39 PM)
Kathleennoel45
QLED and The Frame
Please help. I need a replacement one connect cable that I cannot find anywhere. We just moved and I left the other in the wall.
BN68-07104D bought a few off Amazon (incompatible). any help appreciated!!
Samsung_Moderator
QLED and The Frame
Hi there, Thanks so much for reaching out about this. The best place to find replacement parts and accessories for your Samsung appliances is through our own parts department. You can reach them online at SamsungParts.com or by calling 1-800-627-4368. You'll just need the model number for your TV to ensure compatiblity.
1 Reply
Samsung_Moderator
QLED and The Frame
