Replaced power supply and now have permenant vertical lines
(Topic created: 05-31-2022 03:52 PM)
userGCG0VRgNt2
QLED and The Frame
Heard a pop and then the tv wouldn't power on.  so i researched it and replaced the power supply. I just turned it on to find this. I was very careful and never put pressure on the screen. Is it fixable?
userGCG0VRgNt2
QLED and The Frame
It is a QN75Q60rafxza and it has gotten worse when i took the power supply back out to clean the connections. Does the power supply control the leds?
Bs2209
Sun
QLED and The Frame
You probably bought the wrong power supply and overloaded something in the TV
niceliving
QLED and The Frame
Sorry that happened to your TV.
userGCG0VRgNt2
QLED and The Frame
Apparently the power supply and the led control circuit are on the same board. I bought my part from shopjimmy.com. It is the correct board. same part number and model of the tv. I contacted them last night and a new one is on the way. Hopefully this will resolve the issue.
userGCG0VRgNt2
QLED and The Frame
i got a replacement board to verify and the new board does it as well. So do i need to replace the control board or is it the screen?
