userEMIQcSdFgN
- Mute
- Email to a Friend
‎08-17-2020 04:59 PM in
QLED and The FrameMy Q8C 65" tv getting restart. When i i switch on tv and when the one connect box get hot ( after 30- 40min) then the tv getting restart again and again. If i un plug the tv from OCB then there i no problem. Pls give me the solution and help me to get rid of it......
Solved! Go to Solution.
JohnLoose
Supernova
- Mute
- Email to a Friend
‎08-17-2020 05:03 PM in
QLED and The Frame
https://www.samsung.com/us/support/troubleshooting/TSG01108742/
Hope that helps!
Show me some love with a ❤️
Let me know if this helped by :white_heavy_check_mark: "Accept as solution"
Hope that helps!
1 Reply
JohnLoose
Supernova
- Mute
- Email to a Friend
QLED and The Frame
Hope that helps!
Hope that helps!
