Samsung 70” TV Model QN70Q6DTAFXZA won’t power on.
(Topic created: 08-03-2022 07:04 PM)
userXaHQ6rbVh4
QLED and The Frame
My TV won’t power on.  A dim light in the background flickers, but it never comes on.  It’s a 70” QN70Q6DTAFXZA MODEL, purchased December 39, 2020.  I changed the batteries in the remote.
Diaboyos
Neutron Star
QLED and The Frame
Unless you purchased an extended warranty then the TV is out of warranty and it will be up to you to get it repaired or replaced.
1 Reply
Diaboyos
Neutron Star
QLED and The Frame
