- Mute
05-05-2022 10:06 PM in
QLED and The FrameI have a brand new 2022 frame TV and already am having issues with intermittent sound skipping. It's happened twice now where the sound will skip for a second or less about every 30 seconds or so. I've tried changing cables, and that doesn't help. I've moved my cable box to other TVs, and they do not have the same issue - the problem only occurs with the Frame tv. I do not have a soundbar or any other stereo equipment attached to the TV.
The only way I've been able to fix the issue has been to unplug the power cable from the wall for several minutes. But since the sound problems came back a second time, I'm sure it's only a matter of time before it happens again. Has anyone else encountered this? Any suggestions?
Solved! Go to Solution.
- Mute
08:18 AM
(Last edited
05-08-2022
08:23 AM
by
SamsungLarry
) in
I can definitely understand your concern here. If this is happening no matter what type of device or app you are using to view material, then a factory reset is needed. Please try to remember or write down your display settings before doing so. If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send Message to Moderator
- Mute
05-06-2022 09:00 AM in
QLED and The FrameYour audio drop happens with TV Speakers? What cable box do you have?
- Mute
05-06-2022 12:02 PM in
QLED and The FrameCorrect - it happens with TV speakers.
The cable box is an Xfinity X1 box. I've connected it to other 2020/2021 Samsung TVs and the issue has never occurred on those.
- Mute
08:18 AM
(Last edited
05-08-2022
08:23 AM
by
SamsungLarry
) in
